We have two vaults for two different departments. One uses item masters to control the file and the other uses lifecycle state. We use the web client to view the files. Is there a way to configure the web client to show released items for the first vault and released files for the second vault?
Login to the webcliet as administrator, and you can configure the settings to see items or files to show in released states. This is a global setting, not database specific.
See Image attached.
We may consider to make the item/file configuration settings vault specific, before that, please refer to the work around discribed in http://forums.autodesk.com/t5/Autodesk-Vault/Web-Client/td-p/2884754.
Crisco
