I do not get any warning when I close down a new made drawing which has not ever been checked in. If I forget to check in these drawings and for some reason are forced to clean out my workspace on C:, which has happened, then I might lose a lot of work.
How can I get this warning?
Solved by Cadmanto. Go to Solution.
Solved by cbenner. Go to Solution.
There is no warning that I am aware of for a file that has never been Vaulted. Vault does not know wether you want that file or not, so the best bet is to either remember to Vault everything and/or make sure you have good backups so you can restore anything you've lost if you delete.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
When it comes to new files I am not aware of any message either. In fact, new files do not have a connection to the vault until you check it in for the first time. I know if you are in a session of Inventor and the file has been previously checked in, and you close it you will get prompted asking if you want to check it in. That is where the connection comes in. When it comes to vault a user has to be cognoscent to check in. This is called user awareness. Hate to say it, but it is somewhat like saving. If you don't save often and the power goes out you lose everything.
I check in all the time. A specially if I have done some major changes that I do not want to lose.
If you really think you have something you would like to see in vaul as an enhancement you can always submit it to the Vault Idea Station.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Thanks for your suggestions, all very helpful.
I just thought that compared to many other prompts the system gives this one should actually be nice to have, but off course, if a person always does as he should and never makes a mistake we would not need any prompts at all, would we?
If you do end up posting and idea in the link I provided in my last posting, make sure you paste a link to the idea here in this thread so we can look at it.
