I apologize in advance if this is not if the right place.
In AutoCad Electrical 2013 I cannot login to the AutoCad Vault 2013. I recieve an error that says "_vltlogin unknown command"
I have tried:
* Repairing both the Vault and Electrical installations
* Uninstalling both and reinstalling
* Uninstalling both, deleting registry keys and program data
Also its worth noting that none of the commands in the Vault toolbar in Electrical work. They all come back with "unknown command"
Any suggestions would be appreicated!!
Is AutoCAD Electrical 2013 Add-in checked at Add or Remove Features from the client installer?
Make sure you have loaded the vault.ciux file. It should be loacted in C:\Users\<current user>\AppData\Roaming\Autodesk\AutoCAD Mechanical 2013 - English\R19.0\enu\Support\ and be named VaAc.cuix
