Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Visualization file cannot be created in Vault Pro 2011
2 REPLIES 2
Dan_Malott
1843 Views, 2 Replies
I have autocad and inventor drawings in vault pro 2011 I can select the update view on an inventor part and the visualization file will be updated and works fine.  when I select an autocad file (dwg) I get the error "Update View Restriction"  visualization file cannot be created for "file name.dwg" due to vaulting restrictions.  when I expand the details it stats the File Type is not supported.  2010 used to work fine updating files, have any ideas?
2 REPLIES 2
BassEngineer
in reply to: Dan_Malott
I 've had problems with the Visualization files in Vault 2011 as well.
If you go to  VAULT SETTINGS - VISUALIZATION (tab) - OPTIONS (button) - this will bring up the PUBLISH OPTIONS dialog box...
Change the pull down to AutoCad and AutoCad Common and check the settings...
GC_
Are the vault settings you mention in autocad or vault , I have looked in both but cant find a menu
