Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Visualization created on check in from Acad are wrong....2015
4 REPLIES 4
cbenner
379 Views, 4 Replies
I have my visualization settings in Vault 2015 set up the same way they were in 2013.  For my Autocad products, I have them set to create visualizations from Layout tab, Monochrome, 11 x 17.  In 2013 this was perfect.  From inside Autocad when I check in, I check Create Visualization on Check In, using Default Settings.  What I am getting as a result is a full color dwf of the model tab.  But when I use the Update tool in Vault Client, it repairs itself to the default settings, as it should have from the start.  No Job Processor is being used.  Support Case opened, #09691969  Here are some images.
4 REPLIES 4
cbenner
in reply to: cbenner
r.smith1
Hi Chris,
I grabbed your case and will work with you in the support request.
Ron Smith
New Product Introduction Manager
Autodesk, Inc.
cbenner
in reply to: r.smith1
Telson.Hadden
4 years later - having a similar issue - any idea what the resolution was, if any?
Both Inventor and ACAD Electrical are incorrect here, and even doing a manual update, it's still wrong.
Inventor/Vault/ACAD 2018
