One more thing to test. Does the edit command (launched from Vault
Explorer) work correctly? I'm hoping it does. If so, then the problem is
that you don't seem to have rights on your machine to create a file in a
temporary directory. Viewing (from Vault) downloads files to temporary
directories, editing downloads to the working folder.
Ken
Ken Vadella
Software Engineer, Autodesk, Inc.
"John Evans" wrote in message
news:5147021@discussion.autodesk.com...
Double click and 'open both work fine. They bring up Composer. I am having
trouble with all my software. In the inventor group I have a thread about
this. When I open IV or MDT I get an error [cannot find file 'd3dx9_27.dll].
Is this connected?
"Ken Vadella" wrote in message
news:5146956@discussion.autodesk.com...
John,
Can you tell us what happens when you use Windows Explorer (the Microsoft
file browser) and double-click on a DWF file? Again using Windows Explorer,
what happens if you select a DWF file and use the "open" command in the
context menu (using the right mouse button key)? This information will
likely help us to debug the issue.
Ken
news:5146165@discussion.autodesk.com...
I have PS5 up and running along with DWF viewer. When I try to view anything
in the vault, it tells me that there is no viewer asighed. How do I set up
the viewer to work in PS5?
IV10 SP3a
XP64 sp1
AMD 64 2.2 G hz Opteron
2 Gb ram
(remove the obvious to e-mai)
Nvidia FX 1400
