Hi-
Setting up a new install of Vault Pro with around 26k files. When the files are put into vault using the autoloader, the version of the file and rev level are on the print only. Is there a way to get the version and revision level of the files without opening each file?
I believe that, if you have the properties mapped properly, you should be able to do that with Sync Properties. That should work with Revision at least, I don't think you can change the version number that Vault gives the file, those are imcremented every time the file is checked in.
Vault gurus, feel free to correct me if I'm wrong or missing a step.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
