Hello Dominiek,
If you are asking how to get your Vault 2009 client to work with your ADMS
2008, this configuration is not supported. You should install the Autodesk
Data Management Server 2009 to test with your Vault 2009 client before
upgrading.
Another option is to install the Inventor 2008 client upgrade for ADMS 2009.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10976007&linkID=9242019
Adam
"Dominiek Van West" wrote in message news:5982581@discussion.autodesk.com...
We currently are working with Inventor2008 and Vault2008 (installed on a
server). I made an application which uses these 2. Now we want to switch to
Inventor2009 and Vault2009. So as a test we installed Vault2009 on my
computer (local). What exactly do I need to change in my application (code,
references,...) so I can test my application if it works with Vault2009.
Thanks in advance,
Dominiek
