Hi guys...
So, i have a Vault Pro 2013 Server working fine.
And i need more licenses, but i cant upgrade my server right now, if i buy more licenses, but for Vault Pro 2014 with subscription, and, put licenses in the .lic file, can i use these licenses for Vault Pro 2013 or i need to ask for downgrade?
Solved by ihayesjr. Go to Solution.
I would recommend that you contact your Autodesk Reseller to help with this question.
you would have to ask autodesk or your reseller for a previous version serial number when you buy 2014 vault with subscription
DarrenP
Yes Vault works that way, but you should talk with your Autodesk Partner about the details.
