We are looking at going to Virtual servers in 2014. We currently run WG Vault 2013. Is anyone running 2013 in a virtual server. I kind of need some specs to shoot for.
We have many customers successfully running Vault server on a virtual environment. If you look to the vault readme it gives some general comments about virtual machines. Your allocation of hardware resources for the VM should comply with the system requirements for vault.
One of the best practices of using Vault is to have a testing environment. Often that means a Virtual Machine. It's fully supported & I know of a number of people running VM Vaults in production. Like Ryan said just make sure it has plenty of the resources it requires assigned. I would exceed the recommended specs by some way if I were you.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
