Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault viewer file doesn't match the actual file
11 REPLIES 11
Message 1 of 12
dadirohith
1763 Views, 11 Replies
I have a problem with some of the files when opened in the Vault viewer which doesn't match the actual file when opened in Inventor.(the inventor file is all good)
the viewer file misses all the geometry except the balloons and dimensions and sometimes shows the blurred images with some data missing.
Does any one know what is causing the issues.
thanks
11 REPLIES 11
Message 2 of 12
Neil_Cross
in reply to: dadirohith
The Vault viewer mentioned is the application Inventor View, which you can use without Vault.  The title bar of your viewer says it's opening the IDW, the only viewer that can open IDWs is Inventor View (when you view an IDW in Vault, it just opens Inventor View temporarily).
I guess a good place to start would be to download that drawing to your local workspace, then open the IDW into Inventor View totally separately to Vault and see if the same issue occurs?
Inventor View can be found at Start > All Programs > Autodesk > Autodesk Inventor 2015 > Inventor View
If you still can't see the geometry then there's an issue totally unrelated to Vault, which would then help narrow down the cause.
I'd then be inclined to see if this happens on other drawings or just this one IDW, and do other people (if there are others) see the exact same problem when they do the same thing to the same drawings?
Message 3 of 12
dadirohith
in reply to: Neil_Cross
Hi Neil,
I meant the preview in Vault and the viewer(please find the attached file).
It don't see anything wrong when I view the file from my local space.
We have this problem with some IDW's and Inventor DWG's too and everyone over here has this issue, when I checkout the file and check in back everthing seems ok.(but we have multiple drawings like this).
Even we have this problem when we batch plot the drawings it grabs the DWF's instead of IDW's or DWG's(IDW's or DWG's seems ok but the DWF's misses either text or dimensions or sometimes geometry too.)
But we have some clients using the drawings externally using the web client which can acces only the DWF's(which is the visualisation file) but not the actual IDW's or DWG's.
thanks for your time guys
Bobby
Message 4 of 12
VinceBalge
We are having the same problem. It started after an Inventor Service Pack. There is a Hotfix that is supposed to fix it. Before the Hotfix it was doing this to all DWG files that were processed with job processor. The Hotfix corrected it for some files but not all. Files with objects in model space don't view properly and files with multible sheets don't come out correctly.
Vince B
PDSU 2015 Vault Pro 2015
Message 5 of 12
dadirohith
in reply to: VinceBalge
Vince,
None of us have updated the service pack for Inventor, so I don't know whether it is causing any issues.
Rohith
Message 6 of 12
VinceBalge
Rohith,
I've just un-installed  the Hotfix and Update 1 (INV191110 & INV19111) and my DWF problems have stopped.
I can't tell from the image attached to the first post but it looked like we were having the same problem.
The ghosting on the 2nd and 3rd sheets is from the model not being up to date.
Vince
Message 7 of 12
jake
Hi All,
We have just had very much the same problem. We use Vault Workgroup to manage Inventor drawings. Part of this involves the Job Processor updating the revision table and generating the DWF visualisation file. After installing INV19111 any pages of the DWF past page 1 would have a ghosting effect of just the black line detail (dim line and text).
After reading Vince's post we un-installed INV19110 and INV19111 and the defect stopped.
Thanks for the help Vince.
Jake
Message 8 of 12
DonovanCox
I seem to have the same issue, except Page 1 is fine, page 2 is page one without visible lines and page 3 and beyond are a repeat of page 2.
It's Vault SP1
Inventor SP1 + the updates plus the specifc DWF update
Message 9 of 12
Doug_DuPont
Our problem is almost the same.
We are on Vault 2013 Collaboration and Inventor 2013 Pro
In Vault the dwf does not match the idw.
I can delete the dwf in vault. Then select the open buttom in the bottom pane. It open the idw with Inventor view and it look correct per the revision.
Close that then select update locally, then after the dwf is generated it is different than the idw.
The Revision block is currect, but all the changed that was done are not shown.
I have cleaned out my temp file on my C drive, have a different user do the update that has not dealt with the assembly and drawing at all and it still generates the wrong dwf. Same goes with the Job Processor.
Douglas DuPont
Inventor 2016 Pro, Vault 2016 Pro
Quadro M4000
Windows 10 64 Bit
Message 10 of 12
VinceBalge
We are using 2015 but still see a similar situation. Has the drawing file your having problems with been opened and saved with Inventor? Is the drawing and assembly\parts clean (doesn't want the safe when opened up in Inventor). Are the files in Vault in sync with your computer.
If a part or assembly is modified saved and checked back into Vault without doing the same to any associated drawing files, the drawing still references the previous version of the file and when the DWF is generated with the job processor it uses the newest version of the assembly\part it finds in Vault even through the drawing file still references the old version. We had this problem recently, the DWF generated in Vault showed the correct dimensions, the Inventor DWG was copied out of Vault and sent out to be manufactured referencing an old version.
This can also happen in reverse. If you have a newer version of a file on your computer than the version in Vault. You open the file in Inventor on your computer and everything is correct, but Vault sees an older version and generates the DWF from it.
Another thing to look out for is the "Quick Change" state in Vault. Files in quick change are ignored by the Job Processor.
Vince Balge
Senior Specialist - CAD Systems
ATCO Emissions Management
260 Holiday Inn Dr. Unit #1 Cambridge, ON N3C 4E8
T: 519-220-0600 Ext 239
E-mail: vince.balge@atcoem.com
www.atcoem.com
The information transmitted is intended only for the addressee and may contain confidential, proprietary and/or privileged material. Any unauthorized review, distribution or other use or the taking of any action in reliance upon this information is prohibited. If you receive this in error, please contact the sender and delete or destroy this message and any copies.
Message 11 of 12
DonovanCox
Oddly enough I had my laptop start acting up where I couldn't run Inventor or several other programs so I rolled it back to an old system Image I had taken in June, that seems to have cleared it up. Now DWF files are generating correctly, we'll see how long this lasts.
Message 12 of 12
scottwayand
in reply to: DonovanCox
Just came across this post searching for something else.  I was experiencing this same issue and was able to fix it by following the steps located here.  I did this on all of my job processors and the issue has been resolved.
