Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault To Vault Copy
12 REPLIES 12
Message 1 of 13
383 Views, 12 Replies
Vault To Vault Copy
I would like to copy a data set from one vault to another. It’s over 2 thousand parts so checking them out and into the new one is out of the question. Does anyone know how to do this?
12 REPLIES 12
Message 2 of 13
Why is 2000 parts an issue?
Message 3 of 13
Sorry, short circuit. Depending on their location you can Get Entire Folder
or use Advanced find and get them out all at once. Use the Autoloader to put
them into your other vault.
Message 4 of 13
To uses Autoloader the files will still have to be moved/downloaded to a local spot.
Message 5 of 13
2000 parts should take about 3 minutes to get out of the vault.
Message 6 of 13
Ok, the issue is not the number of files it’s the process. A manual process of checking to make sure that your getting the full data set you’re asking for. I would like to bypass the checking and just get the data no matter what the status is.
Message 7 of 13
My suggestion would be to use Pack and Go on the top-level assembly.
This should make the process of retrieving the files (including the
upstream drawings) pretty simple.
By the way, i'm referring to the pack and go from in vault; not the
"inventor-based" one.
Then, use Autoloader to put them into the other vault.
-Ryan
Ryan Small
SolidCAD
Message 8 of 13
Thanks I just tried.
I would have to do every level one at a time because Pack and Go does not work when using it based on a select of more then one. That would work if the data set were under a single assembly
Message 9 of 13
You may try creating "Labels" from "Tools" menu and use "Pack and Go"
utility in the same dialog. In this way, you can pack more than one
assembly. Please refer the attached image for more information. Hope this
helps.
If you have any questions, please let me know.
Madhan
wrote in message news:5626931@discussion.autodesk.com...
Message 10 of 13
Wow! Great tip Madhan. Thanks!
Message 11 of 13
You are welcome. 🙂
Madhan
"Dave Hoder" wrote in message
news:5629560@discussion.autodesk.com...
Message 12 of 13
That worked nicely
Dave, my file count was 22,000
I was off by some
Thanks!
Message 13 of 13
Glad to hear!
Madhan
That worked nicely
Dave, my
I was off by some
Thanks!
