My suggestion would be to use Pack and Go on the top-level assembly.
This should make the process of retrieving the files (including the
upstream drawings) pretty simple.
By the way, i'm referring to the pack and go from in vault; not the
"inventor-based" one.
Then, use Autoloader to put them into the other vault.
-Ryan
Ryan Small
SolidCAD
dswloram wrote:
> Ok, the issue is not the number of files it’s the process. A manual process of checking to make sure that your getting the full data set you’re asking for. I would like to bypass the checking and just get the data no matter what the status is.
