I typically do a manual check out of files - then simply run the check in
task on them to get the DWF created. even if no real changes happen it
should create a DWF for you.
Brian Roepke
Manager, Customer Success, Data Management
"TRambach" wrote in message news:5821753@discussion.autodesk.com...
> What's the proper method to add a task(s) to task scheduler to checkout,
> create DWF and check back in. I used autoloader to add the files without
> associated DWF's.
