Can anyone tell me if AutoCAD Structural Detailing 2012 is supported as one of the products that allows the basic version of Vault 2012 to be installed?
If so, what would cause the client installation to give the "no other accompanying products found..." message when installing? The AutoCAD software has been registered and is licensed properly.
Thanks!
Hi Dull_Blades,
Please find below the list of qualifying Autodesk products for Vault:
Products | Vault 2012 Supported Add-in Version |
Autodesk 3DS Max | 2012 |
Autodesk 3DS Max Design | 2012 |
Autodesk Inventor | 2012 |
Autodesk Inventor Professional | 2012 |
Autodesk Inventor Publisher | 2012 |
AutoCAD | 2012 |
AutoCAD Mechanical | 2012 |
AutoCAD Electrical | 2012 |
AutoCAD Map 3D | 2012 |
AutoCAD Civil 3D | 2012 |
AutoCAD Architecture | 2012 |
AutoCAD MEP | 2012 |
AutoCAD P&ID | 2012 |
AutoCAD Plant 3D | 2012 |
Autodesk Fusion | 2012 |
Autodesk Simulation Multiphysics | 2012 |
Autodesk Simulation Mechanical | 2012 |
Autodesk Simulation Mechanical WS | 2012 |
Autodesk Navisworks Simulate | 2012 |
Autodesk Navisworks Manage | 2012 |
Autodesk Revit Architecture | 2012 |
Autodesk Revit MEP | 2012 |
Autodesk Revit Structure | 2012 |
Chear Huat.
Is there a way to get the vault toolbar into AutoCAD Strutural detailing?
We are using vault for workgroups throught the company and this includes for Inventor and ACAD Mechanical. We want the guys on ACAD structural detailig to also be able to access vault via their interface.
Is this possible as yet?
