Hello!
Every morning we have a problem reaching our files on server, because disk queue lenght is long. We have found that if we turn off autodesk vault: sql server service - the problem solved. Memory is 3 GB; sql server consume 1,2 GB. Database defragmented. Problem still exist and we have to use the content center. Any thoughts?
fordav
My guess is that the server is running out of system memory, causing use of the page file and hence disc activity.
You can limit the amount of memory the SQL-server is allowed to use (SQL Manager, Properties on the SQL instance)
