New installation of Vault 2012 Pro with SQL 2008 r2. Regarding the backup plan, which product should I backup using Symantec backup exec the SQL backup or Vault?
Solved by herrerh. Go to Solution.
Whenever possible and for the best results when restoring you should create a Vault backup using the ADMS Console, then backup the results of that with Backup Exec.
The ADMS Console backup takes care of both the SQL Databases and the filestore.
