I have been trying to install Vault server and it is failing with the following message: "Install AMS Check. Failed Installation aborted, Result = 2"l . What could be the reason for this message?
Solved by tmccar. Go to Solution.
Hi tmccar,
During the ADMS pre-check prior to installation, we will list the causes, and possible solution to those errors.
Could you help to examine those?
Also, if you could, please send us the log file in %temp folder, that'll help us to do troubleshooting too...
thanks 🙂
Chear Huat.
Hi
When running the System readiness checks, it is failing with the message "ASPX file failed to run at "locahost/testASP/TestASPNet.aspx".
If I try to open that link in a browser, I get the error message "
Handler "PageHandlerFactory-Integrated" has a bad module "ManagedPipelineHandler" in its module list"
OK, it's now installing fine. I got working by uninstalling IIS and also renaming the "c:\inetpubb\wwwroot" folder. I ran the 2012 Vault server installation and let it do the IIS installation, and create the "wwwroot" folder.
