Vault General Discussion
Valued Mentor
9 Kudos
Post 1 of 4
Vault server installation failing
160 Views, 3 Replies
10-15-2011 04:00 AM
I have been trying to install Vault server and it is failing with the following message: "Install AMS Check. Failed Installation aborted, Result = 2"l .   What could be the reason for this message?
OK, it's now installing fine. I got  working by uninstalling IIS and also renaming the "c:\inetpubb\wwwroot" folder. I ran the 2012 Vault server installation and let it do the IIS installation, and create the "wwwroot" folder.
Employee
9 Kudos
Post 2 of 4
Re: Vault server installation failing
10-16-2011 08:01 PM in reply to: tmccar
Hi tmccar,
During the ADMS pre-check prior to installation, we will list the causes, and possible solution to those errors.
Could you help to examine those?
Also, if you could, please send us the log file in %temp folder, that'll help us to do troubleshooting too...
thanks :smileyhappy:
Chear Huat.
Chear Huat
SQA Analyst
DLS- Data Management
Be sure to check out the Vault Help Wiki!
Valued Mentor
9 Kudos
Post 3 of 4
10-17-2011 02:06 AM in reply to: chearhuat
Hi
  When running the System readiness checks, it is failing with the message "ASPX file failed to run at  "locahost/testASP/TestASPNet.aspx".
 If I try to open that link in a browser, I get the error message "
Handler "PageHandlerFactory-Integrated" has a bad module "ManagedPipelineHandler" in its module list"
Valued Mentor
9 Kudos
Post 4 of 4
10-17-2011 04:26 AM in reply to: tmccar
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
