Hello
I am installing a Vault Server Console 2012 to windows server 2003 and got some errors in the middle of installation. I'm inserting here the log file and the screenshot of the actions required. I did all the actions required as suggested from the links but still got the same problem again.
Need your advise.
Autodesk Diagnostic Tool Log File
Checks
Name | Information | Result |
Verifying that a reboot is not pending. | Successful | |
Checking Operating System | Caption=Microsoft(R) Windows(R) Server 2003, Standard Edition CSDVersion=Service Pack 2 OSLanguage=1033 OSProductSuite=272 OSType=18 ProductType=3 ServicePackMajorVersion=2 ServicePackMinorVersion=0 SuiteMask=272 Version=5.2.3790 | Successful |
Checking for a Proxy Server | ProxyURI=http://172.18.66.28/ ByPassList= ^(?:.*://)?172\.18\..*(?::[0-9]{1,5})?$ ^(?:.*://)?172\.16\..*(?::[0-9]{1,5})?$ ^(?:.*://)?172\.19\..*(?::[0-9]{1,5})?$ ^(?:.*://)?172\.22\..*(?::[0-9]{1,5})?$ ^(?:.*://)?172\.28\..*(?::[0-9]{1,5})?$ ^(?:.*://)?172\.24\..*(?::[0-9]{1,5})?$ ^(?:.*://)?172\.25\..*(?::[0-9]{1,5})?$ ^(?:.*://)?172\.20\..*\..*(?::[0-9]{1,5})?$ ^(?:.*://)?teamshimano\.com(?::[0-9]{1,5})?$ BypassProxyOnLocal=true Setup has detected that this computer accesses a proxy server. You should make sure that the proxy server is configured to bypass port 80 on this computer and all client computers that access this one. | Warning |
Validating Performance Counters | Successful | |
Checking port 80 for availability | Does not apply. | |
Validating that IIS Anonymous User Account is set up correctly | Anonymous user "IUSR_SBM-RND" found. | Successful |
Validating that IIS Anonymous Authentication on IIS is set up correctly | Successful | |
Validating IIS .Net settings | ASP.NET filter is not allowed to run under IIS. Please configure IIS Web Service Extension to allow ASP.NET filter to run under IIS. | Failure |
Checking for additional IIS ISAPI filters | Successful | |
Checking IIS directory paths | IIS website Default Web Site root directory = c:\inetpub\wwwroot | Successful |
Determining IIS website Default Web Site Internet address(es). | IIS website Default Web Site server bindings = :80: | Successful |
"AutodeskDM" virtual directory existence check | Successful | |
Check IIS connection time out. | The IIS connection time out is :120. IIS connection time out shouldn't be shorter than 900 seconds. | Warning |
Checking ASP Status | Accessing a static file through the http protocol has passed. ASPX file failed to run at URL:http://localhost:80/TestASP/TestASPNet.aspx.The remote server returned an error: (404) Not Found. | Failure |
Check permissions of the account used by ASP.NET. | Successful | |
Checking SQL version of Vault database instance. | Does not apply. | |
Checking SQL Server 'SBM-RND\AUTODESKVAULT' | The database instance "AUTODESKVAULT" was not found. | Successful |
Checking site compatibility with the database | Does not apply. | |
Checking for existing Vaults with a remote FileStore | Does not apply. | |
Validating that this host name can be resolved on the local network | Server hostname as known by DNS = SBM-RND. Server is resolved to following IP Addresses by the DNS: 172.18.68.40 | Successful |
Checking for known firewall | Does not apply. | |
Check administrative account creation. | Successful | |
Checking for a compatible Security Policy | Does not apply. |
Exceptions
Title | Message |
Exception | The remote server returned an error: (404) Not Found.
Solved by jeromecastaneda. Go to Solution.
Solved by stephen.plant. Go to Solution.
Check your IIS settings for Web Service Extensions as per -
Are your ASP.NET Extensions allowed?
Thanks Stephen
Worked like a charm! I'll give you my handshake.
Regards
Jerome
I have a similar issue, but my .NET extentions are all allowed. I can browse to the static file in IE no problem, but when I try in Firefox, I get prompted for a login. After logging in as admin, I can see the static file. Still, I keep failing the ASP Status Check and only that check. ADMS should be running, but I cannot connect to it with Inventor. What could the problem be?
The initial post was concerning an install issue regarding not being able to install ADMS.
From your question it appears you already have ADMS up and running?
Is this correct?
Stephen
Yes it is installed and I am pretty sure that it is running. How do I verify that it is running?
If you have access to the server you should have an icon for -
ADMS Console
If you have, then run the console and you'll get a window showing you your server details -
This will show you your server name and Vaults.
Stephen
Okay, this is what I have:
If I right-click on the server icon and click 'Administration', I get an error that reads: "Autodesk Data Management Server 2009 could not find the Data Managment Services on 127.0.0.1".
Take a look at this post -
It might give you an idea of where to start.
Stephen
