Hi All,
I am attempting to upgrade a Win 2008 (64bit) server from Vault server 2012 to Vault Server 2013. This server has been running Vault Server 2012 for the past 10 months without a single issue.
During the upgrade system rediness check, I am getting the ASPX error below:
ASPX file failed to run at URL:http://localhost:80/TestASP/TestASPNet.aspx
I have completed every troubleshooting step (including re-installing .NET Framework 4) from the Vault Installation help, but still get the error.
Are there any other troubleshoting steps I can take to get the upgrade completed?
If Andy happens to respond to this post... bummer about your Wings! 😞
Thanks!
Rob
Solved by minkd. Go to Solution.
Unsure what exactly you have with Autodesk, but Brian described how you can download it from the subscription area in the following link: http://crackingthevault.typepad.com/crackingthevault/2012/04/where-can-i-download-vault-basic-server...
If you have one of the "pay for" products it should be on a second disk in your media package.
-Jim
if your using basic vault and product design 2013 it comes on the usb stick or with the product design 2013 download
DarrenP
