Vault General Discussion
tmccar
Message 1 of 8 (600 Views)
Vault Server 2012 on 64-bit PC
600 Views, 7 Replies
08-22-2011 07:39 AM
Can l Vault 2012 Pro Server be installed on a 64-bit system?  I'm guessing not, because I am getting this error message when I try:
"An attempt was made to load a program with an incorrect format"
The SQL Server 2008 install was failing the "performance counter hive consistency" check.
The laptop is a localised Denmark build.
 I exported the following regiatry key:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Perflib\009
006 is the code for Denmark, so I edited this .reg file (changed the 009 to 006) re-imported it and the SQL installation .completed.
Employee
chearhuat
Message 2 of 8 (570 Views)
Re: Vault Server 2012 on 64-bit PC
08-23-2011 02:03 AM in reply to: tmccar
Hi tmccar,
Vault Server 2012 can be installed on a 64-bit PC. Nonetheless, it will be installed as a 32-bit application.
To guide us in troubleshooting, it will be good if you could provide us with the following info:
i. the OS of the 64bit machnie
ii. the installation log file (could be found in folder %temp%, the latest log file)
Chear Huat.
Chear Huat
SQA Analyst
DLS- Data Management
Be sure to check out the Vault Help Wiki!
tmccar
Message 3 of 8 (559 Views)
08-23-2011 05:27 AM in reply to: chearhuat
Hi Chear
   The OS is Windows 7 and it was installed in Denmark
When doing an install of SQL Server 2008 R2, it fails at the followig check:
"Performance counter registry hive consistency"
Tom
Product Support
herrerh
Message 4 of 8 (552 Views)
08-23-2011 06:24 AM in reply to: tmccar
Try rebuilding your peformance coutners using the following:
  • Start -> Run
  • cmd.exe
  • cd C:\Windows\System32
  • lodctr /R
Once the performance counters are rebuilt, try the installation of SQL 2008 R2 again.
-Hywell
Hywell Herrero
Data Management Support Specialist
Product Support
tmccar
Message 5 of 8 (546 Views)
08-23-2011 06:53 AM in reply to: herrerh
Yes i did that but it's still giving the error
tmccar
Message 6 of 8 (537 Views)
08-23-2011 10:01 AM in reply to: tmccar
Employee
chearhuat
Message 7 of 8 (504 Views)
08-25-2011 12:42 AM in reply to: tmccar
Hi tmccar,
Could you share with us the exact workaround you adopt in ur solution? That'll help to benefit the forum users...
Thanks :smileyhappy:
Chear Huat.
Chear Huat
SQA Analyst
tmccar
Message 8 of 8 (493 Views)
08-25-2011 03:53 AM in reply to: chearhuat
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
