Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Restore - Scripted - Select Backup Location?
4 REPLIES 4
mthomas
507 Views, 4 Replies
For redundancy and to provide a "sandbox" Vault for me to play in I'm planning on weekly copying my backup onto a spare system and restore it to the Vault installed on this system. The scripting of the backup and backup copy is not a problem, but I've run into a roadblock with the restore.
Here's the problem... Vault labeles the backup folder with the date when it creates it. For example VaultBackup_2014_03_16_6_00_09_PM
In my script I want to use the restore switch -Orestore  which uses -B to specify the backup location. However if I just specify the folder of the backup (in my case the "v" drive) it fails as it can't find the file specified. How do I configure this to use the backup (or first backup) in this folder?
Mike
Mike Thomas
4 REPLIES 4
JeffPaquette6500
in reply to: mthomas
Can you provide your command string?
Make sure you include the backup folder: (ie: -BV:\VaultBackup_2014_03_16_6_00_09_PM)
Command Line Server Console
Jeff Paquette
Data Management Support Specialist
mthomas
Jeff,
I ended up logging this with support [09368268] and Hywell explained that what I'm after isn't really possible. I wanted to script a weekly restore from a backup file location that will always be different. I'm going to try some command line script magic and see if I can figure it out.
Thanks for the response
Mike
Mike Thomas
cbenner
mthomas
in reply to: cbenner
This is what I'm working with so far...
@echo off
setlocal enabledelayedexpansion
set FolderName=V:\
for /d %%D in (%FolderName%VaultBackup*) do (
SET BACKUPFOLDER= %%D
echo !BACKUPFOLDER!
The catch here is if you have multiple "VaultBackup" subfolders in the directory it will use the last one. I'm anticipating only having one VaultBackup so this should work for me
Mike
Mike Thomas
