Is there a complete procedure for the different replication configurations for the Vault Pro 2014?
Ok Wiki is not bad, and i think the information is complete, but the info is break into segments and at some point we don't know on what kind of config we are. And with this kind of reference, it is easy to miss an important step or an important point.
The advanced configuration don't talk to much about replication.
Please, I need a complete procedure for the full replication strategy from the first to the last steps.
Thank you very much.
Solved by olearya. Go to Solution.
HI Eric,
We have actually switched over from the wikihelp to a new system now, check this out to see if you find this easier to follow, but also be aware we have an advanced configuration guide that goes through the process. The latest version is for 2013 (we have not updated for 2014 as yet), so there is no mention of AVFS technology but the standard configuration process should be accurate:
http://download.autodesk.com/us/vault/documentation2013/2013_Advanced_Config_Guide-2013.pdf
