Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault reindex problem
5 REPLIES 5
tmccar
1018 Views, 5 Replies
I want to re-index a vault of about 176 gig, but it stops atre a few minutes with an error messsage about the timeout. Is there a fix for this? (I have Vault Pro 2012 with SQL Server 2008 R" express)
Tags (2)
5 REPLIES 5
herrerh
in reply to: tmccar
You can change the timeout settings in the web.config file.  More details on making the changes can be found in the Advanced Configuration.
Start y doubling the first value and double the other two if it still fails.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16853779&linkID=9261341
-Hywell
Hywell Herrero
Data Management Support Specialist
Product Support
Autodesk, Inc.
tmccar
in reply to: herrerh
Thanks, that´s what I needed!
tmccar
in reply to: tmccar
I have increased the figure to 1,200,000,000 and it is still timing out.
I notice you say "double the other two", but there are ony 2 variables mentioned in the config guide: "timeouts connection" and "executiontimeout".
herrerh
in reply to: tmccar
In the timeouts sectino, there are three values, connection, defaultCommand and longcommand.  Those are the three that should be changed.
Change them to 360, 720, 2600 as a start.
Change your maxRequestLength back to the default of 51200.
After changing the variables, do an IISRESET.
-Hywell
Hywell Herrero
Product Support
Autodesk, Inc.
tmccar
Thanks, it's running now
