Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault references not migrated
2 REPLIES 2
ctrhenry
261 Views, 2 Replies
I backed up my 2010 vault.
I removed all traces of anything autodesk or MySQLfrom my machine
I installed ADMS 2012 and Vault Client
I am following the read me instructions to update file references and it is giving me an error that the references were not migrated.
Which button did i not press?
Vault server is a Win XP 32 bit machine
2 REPLIES 2
mollons
in reply to: ctrhenry
Are you able to Update File References on small sets of data? Maybe a single assembly?
Do you have a default Inventor project set in Tools > Options?
Do all the files you are Updating File References for fall in the cone of that project?
We made some changes to vault that makes the mass update of file references much less of a necessity. If the update of small sets of data works I'd just leave the update to be done as everyone works.
If file references are needed at the time a command is run the user will be notified and in almost all cases the Update File References command will be run automatically.
Scott Mollon
Quality Assurance
Autodesk, Inc.
Be sure to check out the Vault Help Wiki!
Yes default project set.
I was just following what was in the vault read me pages from the download site. I will try the small set updates. Thanks
