I know that Libraries in Vault are read only. Is there any way to create a read only folder in Vault?
Solved by xavier_dumont1. Go to Solution.
You need at least Vault Workgroup to do that. In VLTW, you can define security on folder per users or per groups.
Hope this help.
If I have VW, but other users will have Vault Basic, will it lock them out from the folders I set as 'read only'?
Unfortunately, all the users will have to be on Vault Workgroup if you have a Vault Workgroup server. We require matching clients to the server.
-Jim
