If you need to share components between folders, in this case ABC parts that
you can use in XYZ's product, then use Place From Vault, browse to the ABC
folder, and place the part. When do you get prompted to create a new ipj
file? There isn't an action that I know of that prompts you to create an ipj
on the fly. If these common components become shared amongst multiple jobs,
then use the Move command in Vault to move them into a folder higher in the
Vault folder structure. The references will update automatically in Vault 5.
From now on, instead of building an Inventor ipj to store files, create a
Vault folder, right click Go To Working Folder, and save the components
there.
Hope this help clear up the mud. Post back with any questions. Post a screen
cap of your Vault if you can. Thanks.
Brian Schanen
Product Designer - Data Management
Manufacturing Solutions Division
Autodesk, Inc.
wrote in message news:5167984@discussion.autodesk.com...
Please correct me if I'm wrong.
We want to set up Vault to have one project file. This is so our parts can
be shared between designs (products).
Let's say we have one folder called "Commercial" and one called "private".
Each of these folders will have numerous sub folders for each customer.
So "Commercial" will have Company "ABC", under that we'll have a "CAD"
folder and a "Docs" folder.
Under the "CAD" folder we'd have a "Production" & a "Prototype" folder.
This is the same set up we'd have for other vendors. But if we have a part
in "ABC's" folder that we can use in "XYZ's" product, we need to have that
choice....thus the single .ipj file.
But as it happens, when a user has a new part and wants to store it in the
vault, it asks them to make a new Project File. Doesn't that defeat the
purpose?
I can't set up a Project File under the Root which is what we need to share
parts not only between "ABC" & "XYZ" but also with any vendors we may have
under the "Private" directory.
Clear as mud?
Please, if anyone can explain the set up I need to do in plain English, I'd
greatly appreciate it.
