Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Pro Workspace synchronization error
5 REPLIES 5
karthur1
314 Views, 5 Replies
Tried to run the workspace sync command.  After a few minutes, the message came up "Some files or folders cannot participate in Workspace Synchronization operation...."
This folder is a locked system folder. Not really sure how to allow access to this folder.
5 REPLIES 5
herrerh
in reply to: karthur1
In your synch settings, are you setting all of D:\ as your workspace?
-Hywel
Hywell Herrero
Data Management Support Specialist
Product Support
karthur1
in reply to: herrerh
where are the synch settings?
If I right click on the Project Explorere ($) and go to Working Folder.... this is set to D:\
herrerh
Sorry, I meant to ask what you working folder was set to.  Since it's set to D:\ and you keep more than just Vault stuff on D:\ and so does the system, you wont be able to get past it trying to check that directory.
I've looked in the config file and do not see a way to exclude files/folders.
-Hywell
Hywell Herrero
Product Support
karthur1
ok... so how is it supposed to work then?  I have my workspace set to D:\.  This is because we use a single project workflow.  My folder structure is like this.  My ipj sits under D:\Designs, then all the working files are under that also manily in the \Drawings folder.
herrerh
Theres a couple options here:
Create a new directory and use that as you're root and place Designs under that.
Or the System Volume Information Directory is for System restore, you can disable system restore for that drive but thats up to you.
I'd go with the first option.
-Hywell
Hywell Herrero
Product Support
