Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Pro Uses Tab
2 REPLIES 2
dbrblg
260 Views, 2 Replies
Vault Pro Uses Tab
I am seeing instances where the assembly file is checked into vault but when I click on the Uses tab there are no part files under the assembly.  They are clearly there as I can open the assembly and everything checks out ok.
It's almost as if the Uses tab has not updated properly.  Has anyone seen this?
2 REPLIES 2
scottmoyse
in reply to: dbrblg
What version of vault are you using? Can you use Jing or Autodesk Screencast to show the issue happening?
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
dbrblg
in reply to: scottmoyse
Hi Scott,
I'm using Vault Pro 2014.  Unfortunately it is an intermittent fault and hard to find instances of so at this time I cannot provide any video Smiley Mad
