Here is the scenario…
I currently have a Production Vault and a Dev vault both are Vault Pro 2013. Both use a remote SQL server. These are both SQL 2008 Full. I have created two more servers as VMs. These are for learning purposes.
With that the one machine will have SQL Express on it. Money savings. I have gone and installed SQL per the Advanced Configuration Guide. I then go to the other server and start the install for ADMS. I put the locations for the remote SQL server in and the share. I am using the default usernames and passwords per the Advanced Guide.
This is the message I get consistently:
Failed connecting to SQL server-
`server=”Servername”\AUTODESKVAULT;user
Id=sa;password=*****;`
I am at a loss why this will not work. I have checked the Firewall settings against the Dev servers. Checked the settings in SQL to make sure the users setup correctly.
Any help in this would be greatly appreciated
Solved by samuel.seah. Go to Solution.
Some things to check:
-Samuel
In addition, make sure that the SQL Browser service is running and set to Automatic for starting up.
thanks both of you for your help. i was able to continue on and get the system installed.
thank you again.
