Anyone using Vault Pro 2013 with Sharepoint integration? I'm just looking for some of your thoughts on what specifically it can do.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Solved by cbenner. Go to Solution.
No tech support needed on this, just looking for opinions.
Chris Benner
Hi Chris,
After a bit of searching for the same information, I saw that you've since implemented your own integrated sharepoint & Vault system.
Is it possible for you to share your experience and answer your own question?
Hello!
Yes, we have implemented this integration, though at this time we're still debating internally on what the best use for it will be. We're looking at creating SharePoint pages for all of our Projects. These pages would then contain links or lists for all of the project documentation from various sources including specs, emails, cut sheets and brochures, calculations etc. Then there would also be Vault lists linking to the latest drawings in the Vault. We're playing with a test project right now to see if this is what everyone will agree on.
One shortcoming we have found, is that we use the Item Master to control life cycles, and use the Watermark to show the current state of the Item. Currently SharePoint will not show this watermark,... so that's a stumbling block I have yet to find a work around for. Autodesk is aware of this, and well aware of my feelings on the issue. 😉
As to how the integration went, I did a 4 part article for Design & Motion on this last summer and posted the links on my blog here.
Hope you enjoy it, and if you have any further questions, feel free to ask. Please start new threads, though, for new questions, so future readers can find them if they do a search.
Thanks!
Chris Benner
Thanks for the link Chris.
I will be sure to have a read of it in my (little) spare time.
Jason
