I have been trying to get administrator access to the thin client for Vault Pro 2015 R2. I have access to read only on the thin client. I keep getting the following message when trying to login with read/write access:
Login Failed
Failed to acquire a license.
I see there is a ****. hotfix for Vault Pro 2015. Is there a hotfix for R2?
Brian
when you log into the webclient with read/write access
it is looking for a Vault Office license which is a separate product/purchase
DarrenP
I am just trying to view .dwf files from Inventor. I have attached a picture of the issue.
This is in the readme file for the Cumulative Hotfix 2 for Vault Pro 2015
Cumulative Hotfix 2 Updates
Brian
Brauls,
As an Administrator, you can log in Read-only and from your login name in the upper right corner you can go into the Administrative settings.
However, If the Inventer file doesn't have a DWF file attached, you will not see a DWF file in the thick client or the Thin Client. This isn't an administrative setting that can be turned on or off. Most likely your Inventor file doesn't have an associated DWF file.
Unchecking the Read-Only option requires a purchase of Vault Office which enables a Thin Client user to check in\out files from the Thin Client.
The issue is that my Designs folder with all my files is not showing up in the Thin Client. See attached picture.
Check the security on the Design's folder. Most likely that is the cause of the problem.
I have checked the security settings on the Folder and it is set to role-based security. See attached picture.
Is there a lifecycle associated to the folder?
Can you also verify that you are connecting to the same server? Meaning the Thin Client is connecting to the same server as the Thick client.
