Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Pro 2015 R2 Hotfix 1 WSE 3.0 Installation Error
3 REPLIES 3
eric.mathews
724 Views, 3 Replies
I'm trying to install the new hotfix for 2015 R2 and I'm running into an issue. I followed the instructions and performed an "iisreset" first and then I get an error box stating that "Microsoft WSE 3.0 is required". I've installed WSE 3.0 I still get the same problem. I'm running Server 2012 R2. Any suggestions?
3 REPLIES 3
r.smith1
in reply to: eric.mathews
Hi Eric,
I see you're receiving a WSE 3 is not installed error when trying to install DM2004210.  Please try these two things.  before restarting IIS, please also go to your task manager and restart the w3wp.exe, then reattempt the install.  If that does not work, please Reboot your ADMS server then try to apply the hotfix.  Please reply with the results.
Ron Smith
New Product Introduction Manager
eric.mathews
in reply to: r.smith1
Hi Ron,
According to our IT site manager the service you are referencing doesn't exist on Windows Server 2012 R2. We've rebooted the server maching several times and the problem persists.
eric.mathews
I found the solution on another post. You have to run the installation from command prompt in administrator mode and the hotfix has to be on the "C:\" drive.
http://forums.autodesk.com/t5/vault-general-discussion/vault-subscription-release-service-pack-1-iss...
