Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Pro 2015 R2 Copy Design Action Rules
3 REPLIES 3
Rag3.b1t
403 Views, 3 Replies
I am currently working with Vault Pro 2015 Copy Design.  I have been enjoying some of the new features of Copy Design.  I had to create a new Action Rule set but only I have access to the new Action Rule set.  I need the new Action Rule Set to be accessible by other none administrator users.
Can anyone help me out?
Thank you in advance.
Brian
3 REPLIES 3
JeffPaquette6500
in reply to: Rag3.b1t
As stated in Vault help:
http://help.autodesk.com/cloudhelp/2015/ENU/Vault/files/GUID-BD61249A-26B6-49DB-A6E5-BE9F1F460CC8.ht...
You must be a Vault Administrator to modify Action Rules.
Jeff Paquette
Data Management Support Specialist
Autodesk, Inc.
Rag3.b1t
I understand that an administrator must set up the Action Rule set.  I would like the Action Rule Set to be stored on Vault Server, so I would not have to install the Action Rule Set on each users computer.
yeakelme
FYI.  For individuals searching for the *.xml files the 2015 R2 external Copy Design utility saves when a custom Action Rule Set is created/configured on an end user's computer with Administrator permissions, the default local folder path is at this location:
C:\Users\<username>\AppData\Roaming\Autodesk\Autodesk Copy Design 2015 R2\CopyDesignRuleSets\*.xml
Please see the attached screen capture image file for further reference.
Also: https://forums.autodesk.com/t5/vault-ideastation/vault-copy-design-2015-r2-action-rule-set/idi-p/553...
Mark
Autodesk PDSU 2016 Ultimate, Inventor Professional 2016 Build: 236, SP2 Update 1
Windows 10 Pro 64-bit, Ver. 1607, Build 14393.1198
Dell Latitude E6530; 16 GB RAM; Core i7-3520M 0 2.90 GHz, 2.90 GHz
NVIDIA NVS 5200M, driver 376.54; SpaceNavigator, driver 10.3.0
