Getting an error with VP2014 Client (SP1). Says that "Given Key was not Present in Dictionary". Get same error on all workstations.
FYI...If I log into VP2013 Client, I can print it with no error.
Screen shot attached....
Thanks for reporting this issue. We are aware of this issue and it is already logged in our system.
Has this been fixed yet? I'm getting the same error. Vault Pro 2014 Sub Rel 1, update 1.
Unfortunately, no In the meantime, you will have to open the change order and then select print from the File menu.
Samuel
