When I select the preview tab of an AutoCAD drawing in Vault and then the [OPEN] button, DWG Trueview 2013 is launched. For a test, I renamed the DWG Trueview 2013 executable and performed the same steps. This time it launched AutoCAD, which is the normal if DWG Trueview is not found. My question is, how can you tell Vault to use DWG Trueview 2014 instead of 2013?
Hi Lancasterm,
You may consider uninstalling TrueView 2013, and re-install TrueView 2014. This should reset the Window OS registry to use TrueView 2014 going forward. Of course this works only when you do not need to have TrueView 2013 and 2014 installed side-by-side...
Chear Huat.
You can set default software to open DWG by doing a registry hack.
