Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Pro 2014 - DWG Trueview 2013 or 2014
2 REPLIES 2
Lancasterm
401 Views, 2 Replies
When I select the preview tab of an AutoCAD drawing in Vault and then the [OPEN] button, DWG Trueview 2013 is launched.   For a test, I renamed the DWG Trueview 2013 executable and performed the same steps.   This time it launched AutoCAD, which is the normal if DWG Trueview is not found.   My question is, how can you tell Vault to use DWG Trueview 2014 instead of 2013?
2 REPLIES 2
chearhuat
in reply to: Lancasterm
Hi Lancasterm,
You may consider uninstalling TrueView 2013, and re-install TrueView 2014. This should reset the Window OS registry to use TrueView 2014 going forward. Of course this works only when you do not need to have TrueView 2013 and 2014 installed side-by-side...
Chear Huat.
Chear Huat
SQA Analyst
DLS- Data Management
Autodesk, Inc.
Be sure to check out the Vault Help Wiki!
edwin.prakoso
You can set default software to open DWG by doing a registry hack.
Try to read this about how you can set DWG launcher.
If this post solves your problem, please mark it as solved. It will help others with a similar problem to find a solution.
Kind regards,
Edwin Prakoso
LinkedIn | Website | Twitter
