Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Pro 2012 export to ERP via XML "Makebuy" property?
0 REPLIES 0
Message 1 of 1
mbaker
472 Views, 0 Replies
Dear Discussion Group...
Recently I've had a client attempting to export to Great Plains ERP solution using the xml export option. Two items are presenting issues:
1. Exporting to ERP via XMP is building an xml file containing a property "MakeBuy" it is not empty and contains a value of Make as default, this is really causing issues at the G.P. level, everything is noted as "Make" including such items as Content Center parts and known purchased parts.
2. What Inventor I-property, File property or Item property is populating this "MakeBuy" variable, we have tested various models with BOM prop's set to purchase, normal, inseparable etc, and cannot seem to find the correct link.
I have attached an image from the "XML" file highlighting the problem variable, any direction or thoughts would be Great...
mb
0 REPLIES 0
