I try to send dwf drawings to a PDF printer. This works fine through the vault plot manager. But when I create a second plot job, also to the PDF printer, I get an error.
When I shut down the vault client and reopen Vault, the Plot Monitor is empty. I can now plot 1 job to PDF printer again. THe second job will again fail, and so on and so on.
Does anyone know how to solve this issue?
This is not possible. The source file is Revit (Rvt). The sheets of a revit file are stored within this file. If you want to put them into the vault, this is the only way. The vault plugin transforms the sheets into dwf. This does not work the same as Inventor or AutoCAD, where a drawing is a seperate file.
