Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Operation Logging
5 REPLIES 5
mwillia1
543 Views, 5 Replies
I found that you can track files deletes by adding the follwoing to the web.config.
<add name="LogFileDeletesBooleanSwitch" value="1"/>
Are there other switches for things like login, checkout, get, etc.?
Matt
5 REPLIES 5
paul.gunn
in reply to: mwillia1
Hi Matt,
You can effectively see logins via logged license activity (Vault Workgroup and higher). And of course checkouts can be searched for (checkout user name) - checkin and adds can be seen via file history.
However there are not really any analogous switches to the delete logging - I think delete was a special case since there is reallly no evidence in the vault after a delete to indicate who performed the operation (or even if it was performed).
Hope this helps,
Paul
mwillia1
in reply to: paul.gunn
Thanks for the quick reply.  That answers my question.  I think we can find the information we need from the iislogs but I wanted to make sure there was not an out of the box way to do it first.  Monitoring file downloads is a security precaution that we wish to take.
jparks_79
Hi Matt,
I am interested in adding this switch to the web.config file. I am curious where the logging information is reported for the deletes? Is it in the standard ADMS log files?
Jeremy
paul.gunn
in reply to: jparks_79
Hi Jeremy,
Yes - this information is in the standard server logs (vlog) .
Paul
jparks_79
Thanks Paul!
