Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
vault not allowing to assign item to iparts
2 REPLIES 2
akosi
464 Views, 2 Replies
hi,
i have an iparts with several length, when i try to assign item to it gives me an error.
it says " operation cannot be performed because configuartion factories cannot be assigned to an item."
thanks
inventor 2011
vault pro 2012
2 REPLIES 2
KooCheeKit
in reply to: akosi
Usually the ipart interested to be assigned with item number is the part requires fabricate or purchase or... If the ipart created from ipart factory have different dimension and so on, then the item number (i.e part number) should be different for each ipart. For example, Combo Plate Lower and Combo Plate Upper are created from ipart factory named Combo Plate iPart as shown below, assuming their dimension are different.
Chee-Kit
Autodesk, Inc.
mollons
in reply to: akosi
You cannot assign item to the factory. You assign item to each instance created from the factory.
Scott Mollon
Quality Assurance
Autodesk, Inc.
Be sure to check out the Vault Help Wiki!
