Has anyone ever created a 'Migration' user profile for Vault?
My question is; What Roles do the need to have it work through Task Scheduler.
I created a Migration Group, and set the Vault Servers correctly. We're having trouble checking files back into Vault via the automated Task Scheduler.
Hi CG,
Do you have any details on the error you are seeing? There should not be any special requirements you require in terms of user access unless you are dealing with released documents and the problem should of course occur on check out.
This issue could relate to file qty - can you test with smaller qty of files? If you have not already seen this, the following may also be of use: http://wikihelp.autodesk.com/Inventor/enu/2014/Help/6177-Installa6177/6178-Data_Mig6178/6179-Data_Mi...
