Fire up Internet Explorer and go to this address:
http://Shvdesign/autodeskdm/services/securityservice.asmx
If that doesn't work, the try replacing the name of the server with the IP address as in http://192.168.0.1/autodeskdm/services/securityservice.asmx
If that still doesn't work, then check the time on the server and set the client time on the workstation to be the same or you can do this via the command prompt: NET TIME \\shvdesign
-Ryan
Ryan Small
National Team Leader, Data Management and Software Development
SolidCAD, a Cansel Company (an Autodesk Platinum Partner)
www.solidcad.ca
