Helo I'm triyng to install language pack for Vault 2013, I can not find one.
At the moment I have the german Vault installed. For Inventor an Mechanical I have the german version with the english language pack.
If I start the english AutoCAD Mechnanical, the Vault Ribbon is shown as below. So it's not possible to checkin and checkout. I tried to use an other VaAc.cuix already, without any changes.
Thanks for help
regards
Bernd
Hi Bernd,
From the Vault 2013 readme:
Supported Client Language Configurations
Any client meeting the following criteria can work with any server of any language meeting the server criteria below. Client language and server language do not need to match.
Hello Allan,
thank you for the answer.
Anyway there is the problem that the vault plugin in in the english version from the native german AutoCAD Mechanical version doesn't works. So it's not possible to check in or check out inside of AutoCAD Mechanical.
You can see this behavior at the picture with the empty ribbon.I could face this prblem on different PC's.
Regards
Bernd
HI Bernd,
Apologies, but it seems as though you are trying to install the English version of the addin on a German version of ACADM? Is that correct?
If so this is not supported - for the German version of ACADM you need the German Vault add in.
Hello Allan,
no I didn't install the english addin in. But if I start Mechanical with the english language pack, the menu Vault is without commands, as you see in the picture before. It would be ok, if the german commands will appearing here.
I tried already to choose another VAAC.cuix without success....( from the english and from the german useres dirctory:
C:\Users\bb\AppData\Roaming\Autodesk\autocad mechanical 2013 - german\r19.0\deu\support
C:\Users\bb\AppData\Roaming\Autodesk\autocad mechanical 2013 - english\r19.0\enu\support
Thank you for help!
Best Regards
Bernd
Hi Bernd,
Inventor and Mechanical must be in German to see the Vault language - it will not appear, if you switch the language.
Vault doesn't have separate language packs like Inventor.
Hope this helps.
Hello Allan!
Does your answer mean that one always has to install the Vault in the same language that Mechanical is used in?
If it is so, the possibilty to use language packs for Mechanical is not as useful as it seemed before.
The situation we are facing is the following:
- a company located in germany
- the Vault server is installed in german language edition
- the Product Design Suite and therefore the Vault is installed in german on the clients as most guys are working in their mother tongue environment
- on every workstation the english language pack is installed as we are working with international subsidaries, sharing screens or having their support by guys working locally in germany with the english environment
How can we ensure that the possibilty to work with Vault is given?
On my machine I have a slightly different installation:
- connected to the german Vault server
- Product Design Suite including Vault Basic installed in english with the german language pack
Within the english Mechanical ribbon I find the german Vault icons.
And within the german Mechanical (language pack) I only find an empty ribbon menu???
Can you guess the reason for this language confusion???
Is there a possibilty to setup two Vault installations instead of the missing Vault language pack?
Best regards,
Lars
Hi Lars,
This is correct
Unfortunately as Vault does not currently support language switching I do not believe we have a work around. I strongly suspect you would not be able to install different language versions of the products side by side.
Language switching is something we are looking to support in the future.
I'm having the same problem. The main company is German but in The Netherlands we're using English for all softwares.
I can switch the language for Autocad (Mechanical) the same for inventor but the plug-in for Vault remains German which is highly disturbing
Please drop a message when an update for this plug-in is available
Thanks for the support
Yours
Clovis
Hello Bernd,
we have the same problem since the last years, a easy but not realy nice option is, to install German VLT Basic after your English Mechanical installation, now your Ribbons exists in your Mechanical German Language Pack installation also in German.
1. Install PDSU in EN
2. Install add LP (DE)
3. Install Vault Prof. in EN
4. Install VLT Basic in DE only if German LP is needet.
Best Regards
Bernd
