when I change the life cycle of a file in vault I would like Job Server / Processor to update the dwf. However, it never happens. The job is never registered in the Job Queue. It used to work before. Are my settings wrong? Where can I set the rules for when an update dwf is to be run?
Please help me, it is such a time consuming task having to "add to queue" manually all the time.
best regards,
Andreas M. Hildershavn
Hi Andreas,
maybe it would help if you would provide screenshots of your configuration.
First question: on the Transition of the lifecycle where you want to have the job running (for example from Work in Progress to Released) on Actions tab: is there Synchronize Propertues and update view jusing Job Server ticked?
Second question: Is the security on the transition restricted?
Third question: how about the security settings of the lifecycles. Does the user who is logged into Jobserver have enough permissions (Read/Write) here?
