One train of though on Vault folder structure is, when possible, try to
mimic the folder structure that you used in your pre-Vault days. This is to
make the transition to Vault easy and familiar. That said, sometimes it is
time to throw out old habits.
Since you will complete ~600-700 jobs this year, you do not want this many
folders under the root of course. Using the Single Project Method with
Vault, consider breaking them into Customers, Frame Styles, Geo's, or any
logical coarse category. Then you could break it down into purchase order,
sales order, etc. In my travels, depending on the duration of the job, I
have seen this broken down further into quarters. This method make the Label
utility a realistic tool to use for design capture.
For long time Inventor customers that relied on multiple ipj's to make
folders, use this methodology minus the ipj in each folder. Keep only one
Single ipj at the top of the hierarchy.
Just beware of using the Vault folders like a file cabinet. In other words,
a 1000 folder, then a 2000 folder, 3000 folder, and so on to represent a
sequential scheme. This tends to bloat the folder structure and impede
workflow. Also, do not fall into having a separate folder for idw, ipn, iam,
and ipt. With filters and sorting you don't need it. It simply demo's better
that way.
Remember that you can create shortcuts to both files and folders. These
shortcuts are unique to your machine but can be copied to other machines.
Create several saved searches as folders to ease the browsing in the Vault
too.
What method will you be using for Libraries? There are several ways you can
proceed, each has its advantages. Will you use Content Center, iParts,
custom iParts?
My suggestions here are only that, suggestions. I think it would benefit
this newsgroup for all to weigh in on how they set up Vault folder
structure. While each company is different, it would give new users a
direction to go. Let's use this post to reply with screen caps of folder
hierarchy and structure for the benefit of all. I'm sure we'll hear from
some of the usual suspects...
Brian Schanen
Product Designer - Data Management
Manufacturing Solutions Division
Autodesk, Inc.
wrote in message news:5130825@discussion.autodesk.com...
Brian,
Yes I will be Vaulting (and all ready have vaulted) my ACAD data. I spent a
weekend (14 hours a day) going through the files and checking them in one by
one. I went back as far as the beginning of this year and the last quarter
of last year. Everything before that is pretty much closed out so there is
no real need to vault it.
Another question... My company will complete about 600 or 700 jobs this
year. Each of these jobs is a large aluminum frame assembly that contains
about 200 to 500 parts in them. Would it be a good idea to organize these
assemblies as different Inventor Projects with each Project having it's own
separate subfolder in Vault (under the Vault root folder)? This is how I
was thinking about doing it. Would you suggest anything different?
