I had Vault Pro client 2014 and 2015 installed on my workstation. I was having problems with the Job Processor running in the background. I decided to un-installed 2015 to see if that resolved my problem. Now I can't get 2014 client to run. I'm getting this error (see attachment). I have un-installed and re-installed 2014 several times, ran a registry cleaner and deleted all the Vault folders I could find. Any suggestions?
Vince
Windows 7 SP1
PDSU 2014 Vault Pro 2014 with Vault Pro Server 2015
Solved by VinceBalge. Go to Solution.
I would Try to remove all autodesk programs from the computer. This has helpped me a few times. It seems that if you want to turely uninstall Autodesk then you need to remove everything. If that doesn't work try creating a new user or rebuilding the account. Sometimes i find its the user profile causing issues.
I managed to solve my problem. I had used uninstall from the Control Panel to remove both versions of Vault. I noticed that Vault 2015 client was still listed on the Autodesk Uninstall Tool in programs. After running uninstall from the Autodesk app and then cleaning up any Vault directories, a clean install of Vault Client 2014 worked.
Vince
