Hi, is it possible to index multiple attribut title block for all tabs using the same attribut name? (Attribut name is ''Title_Block'')
Exemple:
File number is ABB-PANEL-00001.dwg
Layout1 ''Title_Block'' showing a door
Layout2 ''Title_Block'' showing a back plate
Layout3 ''Title_Block'' showing a Hinge
Layout4 ''Title_Block'' showing mounting feets
Etc...
The content of each Tab, are different; Drawing number, Part number, Descriptions, etc...
Layout1 Drawing number=DOOR1, Part number=10001, Descriptions=Door assembly
Layout2 Drawing number=BACK_PLATE1, Part number=10002, Descriptions=Plate assembly
Layout3 Drawing number=HINGE1, Part number=10003, Descriptions=Hinge detail
Layout4 Drawing number=FEET1, Part number=10004, Descriptions=Feet assembly
Etc...
How can i made a Search in Vault Pro 2014, to find the information on all the Layouts Tabs?
For the moment, the Vault seems to see only the first tab in the drawing.
Thank's!
Alain
Solved by ryan. Go to Solution.
DWG Attribute indexing will only read from one of the block instances. The behaviour you are seeing is therefore considered "normal".
If you have content indexing enabled on your vault though, you would be able to search though based on any text string, attributed or not.
-Ryan
