Dear All,
How to turn on the Vault Replication.
I went through the process and followed the same provided in Autodesk Vault Help and was successfull in doing it for one server.
But when i tried the same for another server its giving me error. Then i check in ADMS Console and found that the replication was turned off for that server(ScreenShot of the ADMS Console Screen shich says the Replciation is OFF).
How to enable that option?
I am using Vault 2013 professional with SQL Server 2008 Standard R2.
I want to replicate(Few Fodlers) with Vault Professional 2013 with SQL Express
Regards
Dear Johannes,
Thank you for your reply.
The scenario earlier was both has SQL Server 2008 R2 Standard, it was easy and possible.
The Current scenario is:
Server 1:
Vault 2013 Professional
Server 2:
SQL Server Express 2008
Now i need to replicate(One-Side replication) few folders from server 1 to server 2.
This is the current scenario.
Is this possible?
Regards
Dear Johannes,
Thank you again for your reply and for the link, i have used the same link and performed test replication onother servers and was successful.
Coming your reply
Asuming your reply to both the above is "YES", we can conclude that we cannot Replicate(Uni-Directional) Folders/Files between Vault which does not have SQL Server Standard or Enterprise Edition.
If your answer to the above is NO. Is there any other alternative where i can replicate few folders from Server 1 to Server 2 (Not Bidirectional).
Regards
